Port Forwarding/Incoming Requests
bones123
So I'm trying to set up a home server for hosting my small website, and I noticed that I have no trouble connecting to it from within my network, even from my external IP or the domain name, but anyone outside my network can't see it. I know the ports are forwarded properly since I can get to the website with the domain and external IP, but I've heard that Telus blocks any incoming communications. I wanted to know if this was true, and if so, if there was any way around this or to get those restrictions lifted.
1 REPLY 1
If it's a simple web server and using port 80, all incoming requests will be blocked by Telus. If it's on a random port not blocked by Telus then you may be able to get it to work but no guarantees. A quick search will show all the blocked ports. All residential connections will have the ports blocked. Only way around that is a business package, which allows servers.
