PVR - No sound after Fast Forward
cpm
I lose sound on PVR after fast forwarding through commercials.  I've tried everything I can think of to fix (including replacing HDMI cables) but nothing works.  The only way to get the sound back is to turn pvr off/on, or change the source to something else (e.g. Blu-ray), and back to tv again.  It's driving me nuts.  Has this happened to anyone?
Thanks
1
6 REPLIES 6
Have you completely rebooted the PVR? (Pull power out for 10 seconds)
Yes, I have powered down and restarted a few times.
Is the PVR connected directly to the TV or does it run though something else like a sound system?
As a matter of fact I have been experiencing this exact same issue on my 4K PVR.  It doesn't happen every time but occasionally but I have learnt to live with it.  Sometimes, just going to live TV and coming back fixes it but occasionally I have to reboot the PVR to get the sound back.  I was hoping that the latest firmware update would fix it.  Unfortunately, all other receivers/PVRs got the update but the 4K PVR isn't updated yet.  One of these days!
ugh... 😞  So frustrating.  This has to be a bug that's been introduced.  My setup has worked fine for 2.5 years without any problem.
It is connected to a receiver at the moment.  I have tried connecting directly to the tv and it does the same thing.
