03-25-2018 08:18 PM
03-25-2018 09:25 PM
My Cisco 430 has only ever flashed green around the power light on rebooting. If yours has changed, possibly a firmware update has changed the light to the friendlier green colour. Ultimately, if the reboot fixes issues arising, then the colour of the light shouldn't matter, as you stated.
03-25-2018 08:37 PM
How are you resetting the Cisco device?
03-25-2018 09:09 PM
Just by pressing and holding the power button, until it lights. But it doesn't light red, just green.
03-25-2018 09:25 PM
03-25-2018 09:28 PM
