Improving modem range/power
Reply
Highlighted
Resident
I have a standard modem I received from Telus and it has trouble giving me a signal 15m across my house it's fine in line of site or through one wall. Do I need another modem or a booster?
Accepted Solutions
Highlighted
Most Helpful
Coach
Hello! What is the model of your current modem?
All Replies
Highlighted
Most Helpful
Coach
Highlighted
Resident
The model is Actiontec V1000H
Highlighted
Advocate
This issue that you're having could be asociated with disturbers, so make sure there are none of these near your modem:
  1. Microwave
  2. Televisions
  3. Wireless devices (speakers)
  4. Cordless phones
  5. Etc
You can also check channel settings through the GUI.
For more info, go to telus.com/help or contact technical support.
