07-10-2016 04:32 AM
Since I'm using an old V1000H that is not working very well, how can I use my own router? The V1000H is too old that is doesn't even have bridge mode, or can I get an advanced one as replacement? I'm using 50M so it's supposed to be free right?
07-10-2016 08:38 AM
The V1000 is a gateway, not simply a modem, so you can't simply swap it out. Ask Telus for a replacement if it is constantly giving problems. They will likely send a tech to check for line issues at the same time.
I have always ways found it useful to keep a record of dates and times of troubles to discuss with the tech.
07-10-2016 08:38 AM
07-10-2016 01:56 PM
07-10-2016 02:14 PM
I just plugged my own router into port 1 on the V1000 and it worked fine. My router seemed smart enough to configure without double NAT occuring and I had no problems. (DIR-816L)
07-10-2016 03:03 PM
Thanks. Did you do any setting on your own router? So just plug it in and turn it on?
07-10-2016 02:19 PM - edited 07-10-2016 02:22 PM
You will need a T1200 for single line service or a T2200 for a bonded service to get the "Bridge" mode. You would have to call Telus to get it swapped. Keep in mind you can be charge a service call fee. But not always the case. I had mine swapped out for bad wifi signal less then 50feet away and the range booster always dropped it's connection.
My own router works flawlessly.
The new D-links are a very dumb downed router with the new GUI and barely gives you any feature unlike the older versions of dlink routers. I bought and returned it as soon as i logged into it. Was to simple for advanced user and stripped away any hard core setting a power user would want.
