Home phone doesn't get a dial tone, just white noise.
Reply
Highlighted
Resident
Home phone doesn't get a dial tone, just "white noise". Still able to use for Wifi. Any ideas?
Highlighted
The two are different systems, though carried on the same wire. I suggest calling Telus from another phone to resolve. Or you can try a chat session using your internet connection.
Highlighted
Resident
Thank you. Will do that in the morning.
Highlighted
Also if you're getting static only, check your cordless phones. When mine died a while back all I had on the line was static until I unplugged it and put the phone on the charger for a bit for it to reset.
Highlighted
Resident
Thats very helpful.  Thanks!
