Help Sony XBR850C Purple with Telus 4k box!
Hellfire
Hi all, when I change the resolution on the box to output 4k @ 24 or 60hz I get picture and sound, but the picture is purple!
Anyone know how to fix this? If I change it to 1080p the color is normal....
1 REPLY 1
WestCoasterBC
Telus will have to roll out a software update to correct this. They're aware of this issue.
