Grimshaw, Alberta Packet Loss and Latency issues.
jylee1
Hi, I'm from Grimshaw, Alberta. I have had a few issues with latency when playing games like Overwatch. Granted, the internet speeds here aren't very good in general, but I did a few winmtr tests and the hops to the game servers seem to be a little odd.
I am connected directly into the modem with an Ethernet cable.
I will post the winmtr results here. Please leave a response if there is a possible solution.
The IP of the game server for this test was 24.105.46.130
The link below with be an imgur link of a screenshot of the winmtr test results, as I think its easier to look at than pasting it here. I will also be pasting it here as well.
WinMTR Screenshot: LINK
Below is the winMTR test directly pasted from a TXT document. The IP address of the Overwatch server used for this test was 24.105.46.130.
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.1.254 - 0 | 2416 | 2416 | 0 | 0 | 5 | 0 |
| 10.139.60.1 - 1 | 2393 | 2387 | 25 | 47 | 381 | 54 |
| STTLWAWBCI01.bb.telus.com - 1 | 2404 | 2401 | 53 | 62 | 593 | 55 |
| six.blizzardonline.net - 1 | 2385 | 2377 | 55 | 61 | 367 | 57 |
| 37.244.5.33 - 1 | 2400 | 2396 | 86 | 93 | 443 | 87 |
| No response from host - 100 | 484 | 0 | 0 | 0 | 0 | 0 |
| 37.244.1.103 - 1 | 2408 | 2406 | 87 | 94 | 415 | 88 |
| 24.105.62.153 - 1 | 2382 | 2373 | 94 | 105 | 733 | 95 |
|________________________________________________|______|______|______|______|______|______|
WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
2 REPLIES 2
Which modem / router do you have?
How did you locate the IP for the game server? Was it using the steps Blizzard Support has listed here?
Have you also run the test from the Blizzard side
You can access the server IP ingame in Overwatch. And yes everything seems to be fine on Blizzard's end.
I am using an Actiontec V1000H provided to us by Telus.
