09-23-2016 09:26 PM
Hello,
I would like my Slimline 2 remote to control my projector. It would be set up as my "TV". My projector is a Panasonic PT-AE7000. I have already tried the Panasonic codes, and they don't seem to work. Any suggestions, or can Telus add projectors as devices?
I already have the remote working with my A/V receiver, Denon AVR-2309. It would be nice to control both my A/V receiver and projector with the slimline 2 remote.
Any advice?
Cheers,
Rik
09-29-2016 06:01 PM
You can add your suggestion to the IDEAS section of the Neighbourhood.
09-23-2016 10:34 PM
Unfortunately projector codes are not available to the slimline remote. A remote like the Logitech harmony would work better in this situation.
09-29-2016 05:58 PM
That's unfortunate. I already have a Logitech harmony, but it is quite old. I was hoping to use the slimline 2 for everything.
Is there any way to request projector codes be implemented?
09-29-2016 06:01 PM
