09-25-2016 01:15 PM
09-25-2016 01:16 PM
09-25-2016 04:25 PM
If you've rebooted both by unplugging and by holding the ON button for about 10 seconds, the device may need to be replaced.
09-25-2016 07:25 PM
try holding "power" and "ok" buttons on the box until it restarts. this is a factory reset. u may have to pair with the access point after box is finished initializing
09-25-2016 10:14 PM - edited 09-25-2016 10:15 PM
A factory reset is not something that should be done before completing standard troubleshooting.
