Anyone have a problem with wasps after Telus fiber optic installation where they left an opening?
Andrethedad
We have a nest in the house now.  The used the gap left by Telus as a front door.  Thanks whoever installed it.
3 REPLIES 3
Have you contacted Telus yet? I'd say start with that. Alternately there are fairly inexpensive ways (shop vac) to get rid of the wasps and keep them out. (spray foam)
I hate bugs.... I requested the installer put in extra chaulking!  Need to keep out the ants.
Love the wireless cable boxes.... less need to drill holes.
wayland
Friendly Neighbour
just throw some silicone or conduit putty over the point of entry hole
