04-24-2014 01:04 PM
Hi,
Is there any specific phone features I should look for when buying a phone so that it works with Smart Ring?
Thanks,
Nathan P.
04-25-2014 10:29 AM
Hi, can you give us more details about your service and you wish to do with it? Thanks.
08-21-2014 07:17 PM
I'm using their Home Phone service (and just got their 15/1 Internet package installed today), and I have two separate numbers - one for my phone and one for my all-in-one fax machine. With Smart Ring, there is a different ring pattern between the two numbers, but I haven't been able to tell them apart. I'd like to find a way to know when it's my phone so I should pick up my phone's handset, and when it's my fax machine I need to let it answer.
08-21-2014 07:23 PM
Hi there, the landline/fax device would need to have a distinctive ring feature. Most of them do these days. Generally for example you can switch between different ring sound types depending on whether it's the phone ringing or the fax machine coming through.
