how to unlock huawanie b890 smart hub
hogwild69
How do i unlock huawanie b890 smart hub after getting unlock code from telus?
3 ACCEPTED SOLUTIONS
Yes was given code but no one gave me the procedure where to enter code?
Hi,
I have to sets of steps that may get you to your screen.  If one does not work please try the second.  Sorry I am not 100% sure which one is the correct steps.
  1. Insert your non-TELUS SIM card into the Huawei E5836 mobile Wi-Fi device.
  2. From your computer, launch the 3G Wireless Modem Connection Manager.
  3. If the mobile Wi-Fi device is locked, the following pop-up screen displays: Unlock the data card.
  4. Type the Unlock Code.
  5. If successful, a confirmation message displays. The Device is unlocked.
does nobody re suject anymore b890 b890 B890 B890 B890
6 REPLIES 6
NikkiNiki9Doors
Helpful Neighbour
Good Day,
Yes you have to call into TELUS and request your smart hub unlock code.  It cost $35.00 and the unit has to be activated a minimum of 6 months.
We will be happy to help unlock your device.
Hi,
  1. Insert your non-TELUS SIM card into the Huawei E587 mobile Wi-Fi device.
  2. Connect the mobile Wi-Fi to a working USB port on your computer.
  3. From your computer, type http://192.168.1.1 in the address bar of your browser.
  4. Log into the E587 Web Based User Interface, enter the password Admin and click Login.
  5. Click the Settings Tab > Security > Unlock Device.
  6. Type the Unlock Code and click Apply. If successful, a confirmation message displays.
  1. Factory reset your 890 Huawei hub (optional)
  2. Insert the foreign simcard
  3. Plug your pc via LAN to the 890 Huawei hub
  4. Open your browser
  5. go to the address 192.168.20.1
  6. Login to the hub
  7. You will be greeted with the following:
    unlock
  8. Enter the unlock code you received from TELUS
  9. Click on Continue
Your device is now unlocked. For setting up proper APNs, please contact the SIM Card carrier for those settings as it varries from one carrier to another.
