US travel / roaming
dave_chevyss
If I purchase one of the US travel packages are there roaming fees on top of that amount? Is there anything I need to make sure is turned off so it doesn't roam but can still receive texts and calls? Thanks!!
Chuck81
Organizer
Hi Dave,
if you purchase a roaming pass, your billing for roaming will be applied on the rules dictated by the package you've added. for more details, you can find them here:
http://mobility.telus.com/en/QC/us_travel/index.shtml
Should you decide to only get voice/sms pass and opt out for data, i would highly recommend you turn off your data services or disable data while roaming option turned when you're roaming to avoid data roaming charges.
1 REPLY 1
Chuck81
Organizer
Hi Dave,
