how can i boost cell signal to my smart hub ? yagi antenna?
timber
dont have the best cell reception at my place but smart hub works speed varies all the time was woundering if there was any way to boost cell reception which might improve my serice
See this thread for parallel discussion.
1 REPLY 1
