Why am I not able to connect my iphone to the "applications" icon on the phone?
ireneuyeda
My ipod will open the "applications" icon but fails to open on my iphone.  What's wrong with my phone?  Is it set incorrectly?  Sometimes it works and most times it will not.  Any hwlpful hints?
SaiFi
Organizer
What iphone do you have? 4, 4S, 5? Have you tried resetting your iphone? You can backup your phone, erase everything and see if your application icon responds.
1 REPLY 1
SaiFi
Organizer
