SmartHubs
Reply
FutureFriendly
Good Samaritan
Hi,
I was thinking of getting one of those SmartHubs for my business, I will not be using it for excessive browsing just emails and the occasional Google search, would you suggest this as a good option? And if so, what kind of plans do they offer?
Accepted Solutions
Most Helpful
AskBedo
Connector
Hello FutureFriendly,
You are correct. The Smart Hub is a terrific choice for any type of user, especially for a casual user such as yourself.
In fact, we offer the Cost Assure for Smart Hub plan that fluctuates depending on how much you use in a given month. So go ahead, and give it a try!
The plan consists of a base price at $45/ month which gives you 3GB and is more than enough for a casual emailer & Googler such as yourself.
However if you need to use more, then for another $10 (for a total of 5GB for $55) you will get an extra 2GB, or 5GB of additional data for an extra $15 (for a total of 10GB for $70).
Just to remind you, that you do NOT need to call us to upgrade to the next plan, we will do this AUTOMATICALLY for you once you go over that specific threschold and then revert you back to the basic $45 pricepoint the following month.
If you need any additional information regarding this plan, then feel free to visit this link:
https://businessmobility.telus.com/shop/en/QC/business/plan-multi-tier/Cost_Assure_for_Smart_Hubs/Co...
You can try to estimate your usage amount with the following link and making sure to select Mobile Internet Key (as it is a similar type of usage):
http://businessmobility.telus.com/en/QC/mobile_internet_guide/data_calculator.shtml?skipRedirect
Hope this answered your questions!
All Replies
Most Helpful
AskBedo
Connector
