Smart hub with z-wave or smartthings hub
Reply
Highlighted
Resident
I have just purchased a telus smart hub for my new acreage (as the options are very limited there) and I am looking at setting up some home automation/security devices based on the z-wave or smartthings platforms. I am just wondering if the smart hub is capable of supplying the wired connection that these types of devices require? Please be gentle with me, I feel like I'm turning into my parents when they used to have to get me to explain "this new internet thing" to them.
Accepted Solutions
Highlighted
Most Helpful
I suggest you purchase a router to manage your Smarthome devices, and connect it to the Telus device so internet access is available as needed. This allows your home network to operate as expected, with a router you can easily manage.
All Replies
Highlighted
Most Helpful
Highlighted
Resident
Would a router allow additional devices (above the max. 20) to connect to the smart hub's network as well?
Highlighted
Yes. The new router could manage your entire network, except for traffic to the internet, which would go to the hub.
