How does my business cell phone differ from my personal
Reply
LarryDavid
Organizer
what are the differences
Accepted Solutions
Most Helpful
AskBedo
Connector
Hello LarryDavid,
The personal plans differ from the business plans, but the phones themselves are identical in usability.
For more info on your plan you can check your online account or call us dialing *611 or 1-866-558-2273.
Hope that helps.
All Replies
xl
CPU Alum
CPU Alum
Physically they may not be different....
  • different data and voice rates are available for high volume usage
  • more security may be applied such as VPN's or email connectivity
  • priority resolution when there is a service interruption
Most Helpful
AskBedo
Connector
Hello LarryDavid,
Hope that helps.
