How do I increase with-fi signal strength from router in separate studio building 50' to main house
Reply
Highlighted
Resident
Accepted Solutions
Highlighted
Most Helpful
CPU Alum
CPU Alum
50 feet should be no problem.... there must be some interferance like concrete.
  • What happens if you put the router in a window facing the second building?
  • what happens if you put a repeater in the window?
  • you might also try a directional antenna
All Replies
Highlighted
Most Helpful
CPU Alum
CPU Alum
