How do I block a call
Reply
jrhogan590
How can I block an incoming call
Accepted Solutions
Most Helpful
BitMonkey
Hi Potlass,
Sorry it took so long to respond!
As SarahC responded to jrhogan590, the procedures differ for mobility and landline services, on the mobility side, we are unable to block calls from a specific caller from the network side, it is however possible to block calls from specific phone numbers in most devices;
To adequately answer your question, assuming it pertains to your mobile phone, I would have to know which model you use in order to point you to the correct settings menu.
for example, in Samsung phones you would be looking for a "reject list"  in which you can add numbers you wish to block. On an iPhone, you would go to "settings/ Phone / blocked" and select "Add New..." then input the number you need to block.
Hope this helps!
All Replies
Sarah_Campbell
Connector
Hi jrhogan,
I would love to help you with this but I'm just going to need a little bit more information. Are you wanting to block a number from your mobile phone or landline? It sounds like a silly question, but it's a different process for each.
Hope to hear from you soon 🙂
pootlass
How do I block a caller?
Most Helpful
BitMonkey
Hi Potlass,
Hope this helps!
