Enable call forwarding.
Randy
Helpful Neighbour
Hi. I have a business in Vancouver. I use call forwarding to an after-hours answering service.  My staff use a star code and manually enter the number I am forwarding at the end of each day. Is it possible to have my line forwarded to my after-hours service on a schedule? This would reduce the work for my staff.
Thanks!
Chuck81
Organizer
you can find the instructions here:
http://business.telus.com/business/ab/support/phone/office-phone/how-to/telus-call-forwarding-no-ans...
How to Use TELUS Call Forwarding No Answer
TELUS Call Forwarding No Answer lets you forward a call to a pre-determined number after a certain number of rings.
To set number of rings:
  1. Press *94 and listen for three beeps and then the dial tone.
  2. Press the number of rings that you want your callers to hear (from two to nine).
  3. You will hear two beeps and then hang up.
To activate:
  1. Press *92.
  2. You will hear two beeps. Hang up and your Call Forwarding No Answer is activated.
To deactivate:
  1. Press *93.
  2. You will hear two beeps. Hang up and your Call Forwarding No Answer is deactivated.
1 REPLY 1
Chuck81
Organizer
To activate:
  1. Press *92.
To deactivate:
  1. Press *93.
