Charging Stations?
Resident
Charging Stations?
Hi,
My local hockey arena management has expressed interest in getting a TELUS Charging station installed.  What is the process to fulfill this?
5 REPLIES 5
Community Manager
Hi @hkymom, would you be able to send me a PM with the name and location of your arena? I'm working on getting this to the right people. Thanks!
@hkymom did you find the information you needed from @DanR
Community Manager
Hi @hkymom! I'm looking into this for you and will get back to you as soon as I have an answer on it. Thanks!
Can I get the info as well ?
Community Manager
Hi @Paddy2, these charging stations were part of a targeted marketing campaign and were custom-built. Due to this, they are unfortunately not an item that can be ordered through us. If you're in search of a charging station solution, your best bet will be to look to a dedicated provider, of which many options can be found online. Best of luck!
