CB55's avatar
CB55
3 years ago
Solved
Low temperature alarm & notification
I have an Alarm.com smart thermostat & an emergency low temperature sensor in my basement connected the  Telus security system. However wondering if there's a way to set an alarm + notification to give an earlier low temperature warning (e.g a temperature setting ~5 degrees lower than the heating set point & approx. 5 degrees above the emergency low temp sensor) when the house is left empty e.g. during a winter vacation. This would provide an earlier notification of impending heating problem & sufficient time to correct before freezing.
  • I'm not sure if this is entirely what you're looking for but does this help?
    Log in to the TELUS SmartHome app on your mobile device.
    • Look for the temperature settings or temperature thresholds section.
    • Set the heating set point to your desired temperature for when the house is occupied.
    • Look for the low temperature sensor settings or alerts section.
    • Set the emergency low temperature sensor threshold to your desired temperature for triggering an emergency alert.
    • Look for the temperature alerts or notifications section.
    Set up a new temperature alert/notification with the following parameters:
    • Temperature threshold: Set the threshold to a temperature approximately 5 degrees lower than the heating set point.
    • Notification recipients: Choose the users who should receive the notification.
    • Notification method: Select the preferred method of notification, such as push notification, email, or SMS.
    • Schedule: Set the schedule for when the alert/notification should be active, such as during your winter vacation.
    Save the settings.
1 Reply
  • dru's avatar
    dru
    Save the settings.
