jctf
2 years agoNeighbour
ADT backup battery replacement
I have been trying to reach Telus by phone, but it seems to be impossible. Is anyone from service/Telus monitoring these forums. Please tell your management that they have downgraded their ser...
- 2 years ago
I just replaced the battery in my ADT system a couple of weeks ago. Bought the exact one from Magnacharge Battery for just over $20 and comes with a 1 yr warranty. Easy to replace yourself and way cheaper than Telus.
A-B
Community Manager
2 years agoHello. Do you have the manual for the specific device? It should be listed in there. It depends on which device you're talking about (assuming you're referencing the main command system, which runs on a 3.6V/4.2V 7500 mAh battery) as different ones will need different batteries.
