SaltyApple3
10 months agoHelpful Neighbour
I Can't Top Up Account Because My Balance Is Too Low (Despite I'm Using A Credit Card)
I get an error that says, 'Your account balance is too low to complete the purchase of the feature(s) you've selected. Please top up your account.'
I'm using a credit card which is has no overdue charges. Is this happening to anyone else?
How do I set buy or change my prepaid plan?
- SaltyApple3Helpful Neighbour
I found a workaround.
1. Acquire SIM card.
2. Sign up for a new account.
3. Pick any number.
4. Transfer phone number.
Unfortunately, my number is not yet available and I wish I had've known this before. - SaltyApple3Helpful Neighbour
Thank you, but what if you want to buy another plan instead?
Before, I was using the Talk & Text 100 for a year; it expires on October 13th. I wish to change to Nationwide Talk, Text & Data 150. - TELUS_Support
Thanks for reaching out! That message usually appears when the account balance doesn’t cover the total cost of the add-on or plan change, even if your credit card itself is fine. To fix this:
- Top up your prepaid balance first (even if you plan to pay with a credit card). You can do this through the My TELUS app.
- Once topped up, go back and try to buy or change your plan again.
If you’re still running into the same error, please send us a private message, and we’ll take a closer look at your account to help get this sorted out.
