graym672's avatar
graym672
Helpful Neighbour
5 years ago
Solved
XBOX Connection Issues
It doesn't matter what settings I change, I can manually set up the entire network, port forwarding, upnp, DMZ, it does not matter what I do. The Gateway decides to "help me" and views my xbox as Opt...
  • FuzzyLogic's avatar
    FuzzyLogic
    5 years ago
    Did you reset your network settings on your Xbox to dynamic and get's all it's network info from the router. To me it sounds like you may have old settings on your XBox that don't play well with your current configuration.
