GusV
1 year agoNeighbour
wireless speed slow on Mac mini
I have a Mac mini M2 Pro with WiFi 6e capability. I have Pure Fibre 300 plan which gives me 300 mbps when plugged in directly to the MT3200M modem via Ethernet. However my mac mini is in our basement...
- 1 year ago
The T3200M doesn't support Wifi 6 or 6E. You could experiment with disabling smart steering and setting up seperate SSID's for the 2.4 and 5Ghz bands. This video (skip to about 1:58) for the process:
How To Setup Two Wireless Network Settings on a Telus T3200M router.
If that doesn't help you likely will need to look at getting a wifi 6 or 6E booster.
FuzzyLogic
1 year agoThe T3200M doesn't support Wifi 6 or 6E. You could experiment with disabling smart steering and setting up seperate SSID's for the 2.4 and 5Ghz bands. This video (skip to about 1:58) for the process:
GusV
1 year agoNeighbour
Thanks FuzzyLogic for the tip on how to set the T3200M router. It was very helpful.
Cheers, GusV
