GusV
1 year agoNeighbour
wireless speed slow on Mac mini
I have a Mac mini M2 Pro with WiFi 6e capability. I have Pure Fibre 300 plan which gives me 300 mbps when plugged in directly to the MT3200M modem via Ethernet. However my mac mini is in our basement...
- 1 year ago
The T3200M doesn't support Wifi 6 or 6E. You could experiment with disabling smart steering and setting up seperate SSID's for the 2.4 and 5Ghz bands. This video (skip to about 1:58) for the process:
How To Setup Two Wireless Network Settings on a Telus T3200M router.
If that doesn't help you likely will need to look at getting a wifi 6 or 6E booster.
1 year agoHey GusV - To offer another possible solution to your situation, if your Mac Mini is on another floor, it might be a coverage issue. You might need a booster on the same floor.
As I recall, Apple devices force the 5GHz connection which can have a hard time passing through a floor. I could be wrong about the forced 5GHz connection but a booster will definitely help
- Eric
