stonehorse
5 years agoAdvisor
Wireless much faster than wired (ethernet)
Hello community, I recently dropped my Optik TV service and upgraded my internet from Telus 75 to 150/150. I hardwired to the TV and did a speed test. At very best, I got 97Mbps downloads. Swap out ...
- 5 years ago
The TV ethernet port is the bottleneck being a 10/100 Mbps and not a gigabit port. Mystery solved, thanks xray.
5 years agoHero
stonehorse wrote:I hardwired to the TV and did a speed test
What does this mean? You did a speed test from your TV?
Some TV's (Sony for example) only have a 100 MBps ethernet port but support higher WiFi connection speed.
- stonehorse5 years agoAdvisor
Yes, speed test app on the TV.
Port on TV limited to 100 Mbps? On a 2020 model smart TV, I would hope that is not the case. I'll look into the TV's specs. Thanks for the tip.
- ChrisC5 years agoNeighbour
The TV's port is limited to 100Mbps because the TV does not require more bandwidth than that for any of it's smart TV functions. Manufacturers are not going to spend $ to put in a gigabit ethernet card that is not required by the TV.
- stonehorse5 years agoAdvisorIt would have saved me time and head scratching if the manufacturer just stated the 100 Mbps limit on the spec sheet. I now know 100 Mbps port is more than good enough for 4K. Wireless I'm getting what I'm paying for. Moving on, what would the cost difference be at the manufacturing level for a gigabit port? A few dollars perhaps...I don't know. All a non-issue for me now.
- xray5 years agoHero
I have 2 Sony Bravia 4K TVs and both have 100 Mbps ethernet ports.
You can check the status page of the router for the connection speed.
