SunshineAndSnow
6 years agoNeighbour
Wireless Extenders plugged into LAN port?
I have my Telus modem in the garage in the basement. A LAN cable runs to the main floor and also to the bedroom upstairs (3 levels). I have one Wireless Extender on the 2nd floor, plugged int...
- 6 years ago
They will work happily, and better if both connected by Ethernet. If necessary, you can disconnect the more distant one from Ethernet, and it will act as a mesh connected device at half the speed it currently does.
SunshineAndSnow
It says Model DWS
White flat dish with a blue light.
6 years agoThey will work happily, and better if both connected by Ethernet. If necessary, you can disconnect the more distant one from Ethernet, and it will act as a mesh connected device at half the speed it currently does.
Related Content
Using Ce Smart Plugs with the new TELUS Fiber Modem and Wireless AP devices
Hey all, I've been struggling a lot as of late to get my CE Smart Wi-Fi plugs back on my network since being converted over to TELUS Fiber and being handed a bunch of new equipment (a new Router and ...Solved7.5KViews5Comments
