Esto
5 years agoOrganizer
Wired Telus Boost
Hi there, this seems like a simple question, but I can't find a firm answer: is it possible to connect via ethernet a secondary Telus Boost device? I managed to run a long ethernet cable from th...
- 5 years ago
Try accessing the web interface on the Boost units vis their assigned IP address, rather than through the App, and set them up there.
BC_EZ
What configuration changes were required to disable the wifi connection?
5 years agoThere is a switch in the Wi-Fi configuration screen of the T3200M. Turning it off disables the Wi-Fi.
- BC_EZ5 years agoOrganizer
Thanks (as always!) But I was asking about configuring the boost to use the LAN as the backchannel. I thought that's what you were suggesting.
- NFtoBC5 years ago
Then you’ll need to better describe what you are trying to do.
Sure thing!
I would like to connect two boost discs to ethernet.
Esto started with:
"I read other posts here that seem to imply it's possible to have all Boost units wired, but I can't figure out how to do it. Any hints?"
The accepted answer from NFtoBC was:
"Try accessing the web interface on the Boost units vis their assigned IP address, rather than through the App, and set them up there."
I am not able to find any obvious configuration changes to make when I connect to the disc directly.
Thanks!
