Esto
5 years agoOrganizer
Wired Telus Boost
Hi there, this seems like a simple question, but I can't find a firm answer: is it possible to connect via ethernet a secondary Telus Boost device? I managed to run a long ethernet cable from th...
- 5 years ago
Try accessing the web interface on the Boost units vis their assigned IP address, rather than through the App, and set them up there.
5 years agoWhat happens if you try swapping the two Boost units?
Yes, you should be able to have each connected by Ethernet. You might also need to access the Boost unit using the IP address assigned to it by your router, rather than through the app.
- Esto5 years agoOrganizer
Hi NFtoBC, thanks for the reply, I think you are onto something..
I swapped the units and they reversed their connectivity status, i.e., the one that used to be connected via Ethernet is now wireless, and vice versa (confirmed checking the My WiFi app)
Does this imply an issue with the second switch? I just realized I didn't describe precisely my network. This is how they are connected:
- Modem to T3200M (standard configuration)
- Switch1 connected to T3200M (short cable, living room)
- Boost1 connected to switch1
- Switch2 (in bedroom) connected to Switch1 via long cable
- Boost2 connected to Switch2
Could this be issue? And if so, how could I fix it? BTW, I have a few devices in the bedroom connected via ethernet to Switch2, so I know it works, but maybe it's somehow not compatible with the Telus Boost units?
Another detail I noticed while doing this test swap: After I unplugged Boost1 (living room), Boost2 immediately got a red light status (in the bedroom). Then I unplugged Boost2 and plugged Boost1 in its place and it also got the red status. Then when I plugged Boost2 in its new location in living room it got its blue light as well as Boost1. So, if I only have one Boost unit plugged in to the second switch in the bedroom it doesn't have connectivity, regardless of which actual physical unit is there.
Thank you for your input NFtoBC. Any other hints?
E
- NFtoBC5 years ago
Thank you, I had no idea this was possible. They are both working connected via Ethernet now.
Thanks again!
