RonAKA
6 years agoRockstar
- 6 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
6 years agoHero
RonAKA
6 years agoRockstar
I will be frank and admit that I don't understand what you are talking about. We have the T3200M router which feeds our main Telus PVR with wired Ethernet, plus some other Ethernet connections to printers and a computer. It also feeds a satellite wireless TV box, plus a number of other wireless devices including my iPhone. I have no idea what they are using for connection. My WiFi is a hidden network so when I connect something new, I have to manually identify it and enter the password. Generally everything stays connected fine, except for my iPhone since iOS 13. Can you or someone else give me a little more info on what my options are.
- WestCoasterBC6 years agoCPU Alum
Same process as located here but disabling not enabling. You will then have two separate SSID a 2.4ghz and 5ghz network. If you disable smart steering try connecting to the 2.4ghz network and see if that makes your phone stable.
- RonAKA6 years agoRockstar
I guess I am wondering what happens when I Disable SmartSteering. What will I be presented with for options?
- xray6 years agoHero
RonAKA wrote:I guess I am wondering what happens when I Disable SmartSteering. What will I be presented with for options?
Take inventory of all your devices and count how many are 2.4 GHZ only vs 5 GHz. Keep your current SSID for the frequency that has the most devices to minimize the number of devices you need switch to the other frequency.
Related Content
- 3.5KViews8Comments
