WilliamL
4 years agoFriendly Neighbour
Wifi Issues - Too many devices on one access point?
I currently have the gigabit fibre plan. All my wired devices have no issues and run full speed. However, I get intermittent drops in my wifi connection speed across multiple devices. Right now my ...
- 4 years ago
Update.
I ended up contacting Telus support. They restarted the fibre modem and also factory reset the T3200m modem a few hours ago. So far my cell phone is still showing over 700Mbps connection so hopefully the factory reset is all that was needed. Nobody else in the house is complaining that their internet isn't working yet.
If it happens again I'll setup my boost wifi kit and see if I can distribute the load among a couple more access points.
4 years agoHero
When your devices show a slow link speed is it on 2.4 GHz or 5 GHz?
Do you have Smart Steering on or off?
WilliamL
Smart Steering is enabled.
I did set my phone to manually steer to 5Ghz so I assume that was still on 5Ghz that at the time.
Crossing fingers. I haven't had those drops yet since we factory reset the modem.
- Nighthawk4 years ago
Forcing your phone on to 5GHz could cause problems when Smart Steering is enabled. Smart Steering basically makes the gateway switch between 2.4 and 5GHz depending on conditions. If it switches back to 2.4, your phone may have issues. First thing I did with my T3200 was disable Smart Steering so I have two separate networks. That solved a lot of headaches for me.
- WilliamL4 years agoFriendly Neighbour
Good to know.
I might try that next should this happen again.
I just forced my phone onto the 5ghz so that I would have the best speed when using Steam Link over the wireless, but kept smart steering enabled to have 1 ssid so i didn't have to reconnect all the devices in the house. My parents downstairs have a few devices on the wifi plus my kids devices etc... couldn't be bothered, haha
Since my modem has been factory reset I've left the settings on default for now.
