jimgary
1 year agoNeighbour
Wifi HUB with a single booster
I got a Wifi HUB with a single booster. How do I know the booster is working? I cannot feel the signal is strengthened with the booster.
1 year agoHey jimgary - the booster should work seamlessly with your Wi-Fi Hub. The light status on the front of the booster will tell you if the booster is working.
If you want to see if the booster is working the way it's supposed to, you could unplug it and see if your Wi-Fi gets worse or not
