Bruce88
5 years agoNeighbour
Wifi Connection Issues
So I am a new Telus user who decided to get the 1giga bit plan. The internet works amazing on my gaming devices since i have them connected via ethernet cable. Issue is with the Wifi connection. I am...
- 5 years ago
Are you running IOS 14? There are reported issues with this and wi-fi.
Quickly disable/enable wi-fi on your phone if you are experiencing issues seems to be the quickest way to resolve this.
FuzzyLogic
5 years agoAre you running IOS 14? There are reported issues with this and wi-fi.
Bruce88
Wow, that actually works. Disconnecting then reconnecting helps out a bunch. Definitely beats waiting around for ~5 minutes. Thanks for the help!
