Yatsukin
5 years agoFriendly Neighbour
WiFi Boost and Ethernet
Hi everyone, I've just set up my two Wifi Boost sets, and I'm wondering whether the original one needs to stay connected to the router through the ethernet cable, or whether I can remove it and p...
- 5 years agoYou need the first boost to be connected by Ethernet to the router. The boost units run their own mesh network separate from the WiFi the router runs. You should disable the WiFi on the router to avoid interference and signal congestion.
Yatsukin
Hi xray, thanks for your reply. The boosters came in a pack of 2, so by original I mean the first one of the pair, which is connected to the router by the ethernet cable. I didn't have any boosters before this, but from what I'm reading, it looks like I'll have to get at least one more.
5 years agoHero
- Yatsukin5 years agoFriendly Neighbour
Thanks again, xray. How do I disable the wifi on the router? Will that change the name or the strength of my network?
- NFtoBC5 years ago
The T3200M router requires an Ethernet connection to the first Boost. The newer Arcadian unit does not, once the Boost units are set up, it manages the mesh from the router itself, allowing placement of Boost units away from the router location.
Thanks, NFtoBC! How do I know if this is an Arcadian router? If it helps, it was set up last August.
Grateful for the input. 🙂
- xray5 years agoHero
Yatsukin Look here to identify your router.
https://www.telus.com/en/ab/support/interstitial/troubleshoot-boost-wifi-actiontec-t3200m
