Anon125
4 years agoAdvocate
when will telus stop callers using a fake phone number
it was announced that all carriers had to have the software to stop phone scammers using other peoples numbers. it is NOT happening here. do you still get scam calls from other peoples phone number...
- 4 years ago
As I posted earlier, Call Control absolutely is available for landlines and works the same as the mobility version. Info here: https://www.telus.com/en/ab/support/article/call-control-explained
kamak
4 years agoAmbassador
I remember that Telus had or still has a landline service like Caller Control. Maybe Caller Control does work on landlines?
4 years agoAs I posted earlier, Call Control absolutely is available for landlines and works the same as the mobility version. Info here: https://www.telus.com/en/ab/support/article/call-control-explained
- Anon1254 years agoAdvocate
so if the emergency folks call from a machine that there is an earthquake coming-
etc etc etc
we will not receive that call
- Nighthawk4 years ago
The Emergency Alert System on cell phones would be the way that any warnings would be sent through. It's extremely fast and just pops up the message on your cell while playing an annoying siren. Since it isn't a call, it can't be blocked.
If there is an emergency like an earthquake, the emergency services will not be calling landlines. They never have to my knowledge. They'd have far more important things to focus on if there was a big earthquake coming. There is no system out there that would be able to dial that many landlines at the same time, let alone waiting for all the ringing and then the voicemail, or a busy signal, or a fax, etc. Far too inefficient and extremely time consuming.
we get emergency calls- fortunately test only
