BlairP's avatar
BlairP
Organizer
6 years ago
Solved
When connecting a Boost via CAT5 does it have to be direct?
To help my performance on my home WiFi, I want to connect one of the Boost devices via CAT5/Direct cable. However, given that the home (Telus) modem is in the basement, I need to use a cable connect...
  • NFtoBC's avatar
    6 years ago
    Change the router to a switch, or to act as a switch, and you should be OK. The Telus gateway (modem/router) has to be the device assigning IP addresses to the Boost Device.
