Riverbend9
2 years agoNeighbour
Water is flooding through Telus conduit which cable into house
Found out this afternoon water is pouring from Telus cable pipe, which connects to wire box to the house. No issues of other utilities conduits right beside outside the house. Telus digged and buri...
- 2 years ago
The conduit is open at both ends. If the end in your house is lower than that at the street, and the water table is high enough, you can get you could get water at your house. You could get some plumbers putty at the hardware store, and plug the end of the pipe.
polecat
2 years agoAll-Star
Riverbend9 Most of western Canada is in a drought. Yes the pipes will fill with water cables are good for direct burial. Search your yard for an unusual green area in lawn you might find it. Call town city and they should come and check for a leak. May end up in your basement.
Riverbend9
The city tested sump pump water. It's not tap water after testing (not turning pink). The main water is on the grass, other side of Telus line. The leak has stopped several hours after rain. It's Telus didn't bury 5G fiber cable property, and they can said it's a by- product to use their service to have a bonus flooding.
