RonD
2 years agoNeighbour
Volume Control
Using an Optik TV-21T box with a Monitor type TV, so no tuner and no internal speakers, HDMI cable hook up Monitor has optical audio out but its fixed not variable same as the Telus box's optical...
- 2 years ago
Hi RonD , this is outside of our support, but perhaps you can try the following to see if it will work:
1. Hold Input and Left on the DPad for 3 Seconds
2. LED on remote should be solid green
3. Press OK
4. LED on remote should blink white, green, white, green
That command locks the volume control to the STB
2 years agoHi RonD to my understanding your remote should work for both. Have you contacted our technical support team for assistance?
