Akhil271's avatar
Akhil271
16 hours ago
USING TELUS BOOST 7 WITH TELUS 6E ROUTER
I recently moved into a new house where i have the telus boost 7 router connected to the NAH on the main floor. I have my older telus 6E wired via ethernet (also connected to NAH) down to my basement to help with poor network downstairs.
Am i able to operate both routers as a standalone router with separate SSID, without creating a mesh? I am looking to set them up with separate SSIDs so that my devices don't keep on switching between wifi7 & wifi 6E networks.
Appreciate any information on how to get this networked as i like. Thanks.
  • Thank you for the reply.
    I hadn't tried Bridge mode as I assumed it wouldn't work as both the routers, Boost 2 & Boost 3 are from Telus and not a third-party router.
    I will give that a try and update the forum.
    Thank you so much.
  • TELUS_Support's avatar
    Hey Akhil271 - Have you tried configuring the basement unit in Bridge Mode (Access Point Mode) via the web interface to prevent dual-NAT, this might ensure they function as independent Wi-Fi sources connected to the same NAH.
