Akhil271
26 days agoNeighbour
USING TELUS BOOST 7 WITH TELUS 6E ROUTER
I recently moved into a new house where i have the telus boost 7 router connected to the NAH on the main floor. I have my older telus 6E wired via ethernet (also connected to NAH) down to my basement...
Akhil271
25 days agoNeighbour
Thank you for the reply.
I hadn't tried Bridge mode as I assumed it wouldn't work as both the routers, Boost 2 & Boost 3 are from Telus and not a third-party router.
I will give that a try and update the forum.
Thank you so much.
25 days agoPlease let us know!
- Akhil27124 days agoNeighbour
The solution did not work. I changed the NAH to port 1 bridge then connected the wifi 6 AP to port 1 leaving the wifi 7 AP on any of the other remaining ports.
Both AP's still had the same SSID, plus it wouldn't allow me to log into the IP for the access point to change the SSID.
I guess i will just settle for a after market AP for my basement or just make peace with using the same SSID on both APs.
Thank you for the help though.
