mkanwischer's avatar
mkanwischer
8 months ago
Solved
Using T3200M with Boosters
I'd like to know if a T3200M can participate in the mesh network when one adds 2 Telus WiFi 5 boosters?  I currently have my first booster plugged into the T3200M via ethernet, but it is in a room a ...
  • El-Eric's avatar
    8 months ago
    Hi mkanwischer​ - the T3200 won't participate in a handoff with a booster. You can set up the same SSID and Password on all your equipment but the boosters are able to mesh and perform the handoffs without any work needing to be done. On the T3200 you'd need to manually disconnect from it and connect to your boosters
