Fernwood's avatar
Fernwood
Organizer
4 years ago
Solved
Using Boosters to boost guest & smart device subnets? Or only main network? (white cylinder modem)
Hey all, I have the wifi hub modem from Telus (it's white, shaped like a cylinder), and I've gone through the Admin options to enable both the Guest network and the Smart Device network. I also have ...
  • giantbrownguy's avatar
    giantbrownguy
    4 years ago
    As far as I have seen there's no way to configure which network the Boosts support. I think the guest is only driven by the router and the Boosts will focus on the primary network. You might want to try getting a dedicated separate router to bridge off the Telus router to run your smart devices.
