Pepperwood
3 months agoNeighbour
Using a Boost W-Fi 6 as a wireless booster
Hello, I have a new Boost 7 that is connected to the NAH via Ethernet. I am wondering if it is possible to use a Boost 6 as a wireless booster in the basement without needing to connect it to the NA...
Smelo
Apologies, to answer your original question on this. You need to hardwire each Boost (6/7) to the network via ethernet. That's either via the NAH box or another boost box, or a switch. Anything connected on the same network should work. The purple port on the Boosts are the "network in" or for older tech the "WAN" port. Use that port when connecting them to your network. Cheers
