AusMiller
5 years agoNeighbour
Use home Ethernet & Improve Wifi - Telus Fibre (ONT & T3200M)
Hi there. We have a new home that was built with 2 roughed in Ethernet lines, one to the main floor and one to the second floor, both feed individually from the basement panel. We have Telus fibre int...
5 years agoMy suggestion:
- place the T3200M in the basement, connected to the 2 Ethernet cables
- put a switch on each floor to expand your LAN
- get the Boost Wi-Fi starter pack, and place one on each floor, connected to the switch.
AusMiller
Thank you NFtoBC, will give this a go, your solution is a lot easier than I thought it would be!
