J_Y117
4 years agoOrganizer
Upgraded Smart Hub Question
Hey All, For anyone who has the new 5G Smart Hub, can anyone say whether the hardware supports a bridge mode? I currently have the old LTE hub and I'm considering upgrading to take advantage of t...
kamak
4 years agoAmbassador
For an AP, you don't need to setup bridge mode with a router. If the Telus router/Hub has a ethernet port you can connect another router/AP to it, or a wireless extender to said hub.
J_Y117
True but I also want to get a UniFi setup as well and use their hardware as the primary devices rather than the Telus all in one.
- kamak4 years agoAmbassador
Which Unifi device? A switch, an AP? All of which I'm pretty sure doesn't require bridging. What is the exact signal/equipment path you want to use?
- J_Y1174 years agoOrganizer
Switches along with an AP or two, depending on which ones I go with and the effective range/pricing/etc.
Main routing device would be a Dream Machine or Dream Machine Pro, haven't quite decided on that one as it depends on which one is in stock and I can actually get my hands on.
I'm looking to use my own hardware for the actual network side of things, not the Telus device. I only want the signal passed through from the Telus device, nothing more. I want my Ubuiqiti device doing the routing and all the networking config.
Well I'm sure you can get everything you want without bridging. Just in case you can't do it with the device they give you, whatever that is, an ONT/Router/WiFi Hub. What is it you think or know that you are going to benefit from by using your own router as the actual WAN side to WLAN/LAN as a singular device? The New Telus Hubs and ONTs are all 2.5Gbe
I personally was looking to try to future proof (within reason) my new home's Network/WiFi, by getting a 10Gbe x 2.5Gbe multiport POE switch and some 2.5Gbe APs, but that's it, I'll use the Telus ONT and or Router/Hub as the WAN side as long as I can connect to it/them with the 2,5Gbe port from either one of them as need be. I have no know reason or need to use my own ONT/Router for the WAN side.
