Tbenoit65
2 years agoNeighbour
Tv sound keeps cutting out.
Unplugging and plugging it back in doesn’t fix it. Cable tv is fine . Telus is the problem. Nothing fixed it
jackrabbit000
1 year agoLeader
Sound fading on me also.
1 year agoCan you provide us with your app version, and
a) does it happen on VOD, live TV, recordings, only some channels, etc?
b) Does the sound fade in and out or just goes down and stays down
c) how often is this happening? Is it after the box has been on for a certain period of time?
d) does restarting the box fix the issue (even temporarily)?
- RebekahDelia1 year agoNeighbour
Only CBC is cutting out. All other channels are fine. The sound is stuttering.
- TELUS_Support1 year ago
Thanks for reaching out! If only CBC is experiencing issues while other channels are working fine, it may be a signal-related issue with the channel itself. Try rebooting your TELUS TV box and router to see if that helps. If the issue persists, let us know.
